Engine
Fuel system
Fuel injection: ø38 mm x 4 (Keihin) with oval sub-throttles
Ignition
Digital
Starting
Electric
Lubrication
Forced lubrication, wet sump
Engine type
Liquid-cooled, 4-stroke In-Line Four
Displacement
1,043 cm³
Bore x stroke
77.0 x 56.0 mm
Compression ratio
10.3:1
Valve/Induction system
DOHC, 16 valves
Transmission
Clutch
Wet multi-disc, manual
Primary reduction ratio
1.627 (83/51)
Gear ratios: 1st
2.692 (35/13)
Gear ratios: 2nd
1.950 (39/20)
Gear ratios: 3rd
1.529 (26/17)
Gear ratios: 4th
1.304 (30/23)
Gear ratios: 5th
1.136 (25/22)
Gear ratios: 6th
0.958 (23/24)
Final reduction ratio
2.867 (43/15)
Transmission
6-speed, return
Final Drive
Sealed chain
Frame
Frame type
Aluminium twin-tube
Rake/Trail
27˚ / 107 mm
Wheel travel, front
150 mm
Wheel travel, rear
150 mm
Tyre, front
120/70ZR17M/C (58W)
Tyre, rear
180/55ZR17M/C (73W)
Steering angle, left / right
34˚ / 34˚
Suspension
Suspension, front
43 mm inverted fork with stepless
rebound damping and spring preload
adjustability
Suspension, rear
Horizontal Back-link, gas-charged,
with stepless rebound damping and
remote spring preload adjustability
Brakes
Brakes, front
Dual semi-floating 300 mm petal discs
Caliper: Dual opposed 4-piston
Brakes, rear
Single 250 mm petal disc
Caliper: Single-piston
Dimensions
Dimensions (L x W x H)
2,235 mm x 900 mm x 1,405 mm / 1,430 mm
Ground Clearance
155 mm
Wheelbase
1,520 mm
Seat height
845 mm
Fuel capacity
21 litres
Curb Mass
239 kg
Performance
Maximum power
86.8 kW {118 PS} / 9,000 rpm
Maximum torque
102 N.m {10.4 kgf.m} / 7,700 rpm
Versys - oprema, servisi i sve ostalo
- Vozim: versys 1000
Re: Versys - oprema, servisi i sve ostalo
Versys 1000 ce imati ABS, kontrolu proklizavanja preuzetu za ZZR1000, i dva moda voznje gdje je slabiji iskoriscava 75% snage motora. U odnosu na Z1000 isporucuje vise obrtnog momenta u nizim i srednjim okretajima.
Po savjetu Borisa kupio sam Pireli angel ST, jedva ceka, da ih "smontiram" pa da probam kako ce Kawasaki da se slozi sa njima...
ja sam sa pireli diablom prezadovoljan
Bile su mi Dunlop sportske gume, qualifqaer 2 tako nesto, i kada su hladne umio je da prokliza, na kisu sa srecom nisam ih vozio par puta po gradu me uhvatilo, i nisam se pitao sa zadnjim tockom... Ove su sport/turing tako da iam od njih velika ocekivanja...DrMracni wrote:ja sam sa pireli diablom prezadovoljan
Bices prezadovoljan. Ja sam sa njima opalio pola prosle sezone i pocetak ove. oko 16000-17000km. Ni u jednom trenutku me nisu izdale. Jedini razlog sto sam kupio Michelin poslije ovih je cista radoznalost, da probam neke druge gume.
ono sto me je odusevilo kod pirelija da se po kisi ponasa bas odlicno, ne kliza ni na naglo dodavnje gasa. po suvom standardno dobro...SlavkoPejovic wrote:Bile su mi Dunlop sportske gume, qualifqaer 2 tako nesto, i kada su hladne umio je da prokliza, na kisu sa srecom nisam ih vozio par puta po gradu me uhvatilo, i nisam se pitao sa zadnjim tockom... Ove su sport/turing tako da iam od njih velika ocekivanja...DrMracni wrote:ja sam sa pireli diablom prezadovoljan
dunlop manje vise, svaki se isto ponasa. kad je hladna guma nije bas dobra
- Space Director
- Vozim: TDM 900
bokibd wrote:Bices prezadovoljan. Ja sam sa njima opalio pola prosle sezone i pocetak ove. oko 16000-17000km. Ni u jednom trenutku me nisu izdale. Jedini razlog sto sam kupio Michelin poslije ovih je cista radoznalost, da probam neke druge gume.
Tek ces sad da se prijatno iznenadis. Po svim testovima, guma je .... TOP
Imam 'velika' ocekivanja od Pirelli-a za iducu sezonu... Ove sam presao cca 13-14.000km. Sledeca moze biti samo 'duza'... Juce sam ga 'spakovao' na 'veliki' servis... Zasluzio jeSpace Director wrote:bokibd wrote:Bices prezadovoljan. Ja sam sa njima opalio pola prosle sezone i pocetak ove. oko 16000-17000km. Ni u jednom trenutku me nisu izdale. Jedini razlog sto sam kupio Michelin poslije ovih je cista radoznalost, da probam neke druge gume.
