Gilera Fuoco
kopljas
Vozim: Honda Africa Twin RD07
Gilera Fuoco
Post by kopljas »
Pre neki dan u centru Podgorice naleteh na najcudiniji skuter koji sam ikada video. Zapravo, to je bio ujedno najcudniji i najlepsi skuter :) Ja nisam neki ljubitelj tog tipa motora, ali moram priznati da mi je neobican izgled ovog drumskog majstora, privukao paznju.
Malo sam procunjao po net-u i nasao sam sledece:
Engine - Single cylinder Master 4 stroke with double ignition, four valves, and electronic fuel injection
Displacement - 492.7 cc
Fuel - unleaded petrol
Compression ratio - 10-11: 1
Max power - 40 HP (29.5 kW) at 7,250 rpm
Valve train - (SOHC) 4 valve, electronic injection
Ignition - Electronic inductive discharge and variable spark advance in electronic unit with electronic immobilizer. Fuel pump shutoff when bike tips over. Two spark plugs.
Cooling - Liquid with three-way thermostat
Length - 2,160 mm
Width - 775 mm
Wheelbase - 1,550 mm
Seat height - 785 mm
Dry weight - 244 kg
Fuel tank capacity - 12 litres (includes 1.8 litres reserve)
Max speed - Approx. 145 Km/h
Distance covered under ECE Euro 3 conditions - 21 km/l
kopljas
Re: Gilera Fuoco
Post by kopljas »
goku
Vozim: Honda PC35
Re: Gilera Fuoco
Post by goku »
A jel' dodje ova teta sa njim?
Re: Gilera Fuoco
ima kroz Budvu jedan isti...vjerovatno je to taj ...velika britanija table :D
Ivan Grozni
Vozim: V-strom DL650
Re: Gilera Fuoco
Post by Ivan Grozni »
Ukusi su razliciti...
Meni se ipak mnogo vise svidja piaggo-ov model mp3 od ovog cudovista :D !
Gugi
Re: Gilera Fuoco
Post by Gugi »
Tako je ermano....mada menE se najbolje svidja Mp3 + teta=ja.....
Deadly
Vozim: Yamaha X-max 125
Re: Gilera Fuoco
Post by Deadly »
Ovaj motor izgleda kao malo oklopno vozilo , svaka cast dizajneru. :text-bravo:
Ova teta na slici je :angry-devil:
Re: Gilera Fuoco
Evo opširan test u Moto Pulsu
http://www.motopuls.hr/images/stories/T ... o500ie.pdf" onclick="window.open(this.href);return false;
rezime:
+ izgled, kvalitet, stabilnost na pravcu, kratki put kočenja
- cjena, krajnja brzina, prostor pod sjedištem
Re: Gilera Fuoco
Ovaj motor je jednog momka iz Podgorice i bas izgleda kao kakvi pojacani R2D2 :D sto se tice ove ribe ona mi se cini da je sa zabjela i da je masinsku zavrsila,radi ka frizerka u blok 5 :lol:
P.S.volio bih da se primi na mene kao na ovu kacigu!!!
Re: Gilera Fuoco
Post by LION »
....ostavite i meni malo :lol:
