Gilera Fuoco
Posted: 03 Sep 2009 18:11
Pre neki dan u centru Podgorice naleteh na najcudiniji skuter koji sam ikada video. Zapravo, to je bio ujedno najcudniji i najlepsi skuter
Ja nisam neki ljubitelj tog tipa motora, ali moram priznati da mi je neobican izgled ovog drumskog majstora, privukao paznju.
Malo sam procunjao po net-u i nasao sam sledece:
Engine - Single cylinder Master 4 stroke with double ignition, four valves, and electronic fuel injection
Displacement - 492.7 cc
Fuel - unleaded petrol
Compression ratio - 10-11: 1
Max power - 40 HP (29.5 kW) at 7,250 rpm
Valve train - (SOHC) 4 valve, electronic injection
Ignition - Electronic inductive discharge and variable spark advance in electronic unit with electronic immobilizer. Fuel pump shutoff when bike tips over. Two spark plugs.
Cooling - Liquid with three-way thermostat
Length - 2,160 mm
Width - 775 mm
Wheelbase - 1,550 mm
Seat height - 785 mm
Dry weight - 244 kg
Fuel tank capacity - 12 litres (includes 1.8 litres reserve)
Max speed - Approx. 145 Km/h
Distance covered under ECE Euro 3 conditions - 21 km/l
Length - 2,160 mm
Width - 775 mm
Dry weight - 244 kg
